I'd also sand w/2000 for some tooth. *NM*
Aftermarket resin kit I bought. Super glue or Epoxy will not stick to it. How do I build it? *NM*
Need to clean it more *NM*
Wesley's Bleach White for 24 Hours *NM*
If you bought it from its maker, contact him with your question. Different resins and mold release types can vary what technique and solution are safe and effective for cleaning. Sometimes you need to clean the initial cleaner off, too. *NM*
Agreed. CA or epoxy should stick to it nicely. Must still be a lot of mold release on it. *NM*
Not until after the bleach bath. Otherwise, you'll just push the mold release into the surface as you sand. *NM*
I did not know that. THANK YOU, TERRY!! *NM*
Thanks. I didn’t know that either. *NM*
