And, didn't UV light cause the yellowing in the first place? Always sounded like "snake oil" to me *NM*
IF it works (never tried it), might a UV light (for indoor plants) work? *NM*
Quick question. What is the trick on putting old decals in the sunlight. Do you need to put them outside or does it work thru a window, *NM*
Inside, watch for condensation with single pane windows though *NM*
I taped it to the inside. I guess that may be a bad idea. *NM*
Maybe put it in a small plastic bag, then tape that to the glass? *NM*
I'm ignorant on this subject. What is the reason for putting old decals in the sunlight? *NM*
The theory is that the ultraviolet rays "bleach" away the yellowing that commonly occurs to the carrier on old decal sheets... My experience is that it doesn't really work. *NM*
Sunlight will also beach out some of the color. Plus, since so much modern window glass blocks UV rays, it might not work at all for you. I tried it, and it did not work. *NM*
I just looked it up, and yes, UV causes "photo-oxidation", which can result in light-colored plastic yellowing over time. I guess it makes sense, since the decal film is a type of plastic. *NM*
To bleach old yellow decals. *NM*
